Many Questions
207Driver
Many Questions
Message par 207Driver »
Hello everybody
excuse me my French and my English is not so good...
I need information for my scooter (s57c)
1. What a spark plug is used?
2. on the nameplate stands Peugeot 557. What does this mean? is it a model of griffon fmc ?
3. Is there on the engine cover a holder to hold the cover (maybe someone has a photo so I can rebuild this)?
Thank you for your answers!
Regards from Swizerland
Re: Many Questions
Spark plug : NGK B6HS
Griffon/FMC 557 = Peugeot S57
Engine cover :
207Driver
Re: Many Questions
Thank you for your help!
Have some other informations about the historie or the number of produced S57C/557?
1 month before i wrote peugeot museum for a kopie of manual or something like this.. But no answer...
You have one?
With th holder i mean a stick that holds the cover in " up-position" to work on the engine maybe..
Thank you
Regards
Re: Many Questions
I don't know how many scooters S57C were produced.
Concerning S557 you won't receive an answer from Peugeot museum since it is not a Peugeot. Send us a picture of your scooter so that we can identify what is it.
To maintien the cover in up-position, use the strap, which you can stretch out at the hook : See the attached photos
207Driver
Re: Many Questions
Here are some photos.
Re: Many Questions
As far as I can see on your pictures, your scooter is a Peugeot S57C.
The type and the serial number are carved on the steel frame (see attached), in the glove compartment/the toolbox. Is the same thing written everywhere ?
The guy who made the manufacturer's data plate may have made a mistake and he may have replaced 5 by S ?
Wie es auf deine Fotos erscheint, ist dein Motoroller ein Peugeot S57.
Die Art und die Fahrzeugnummer wurden auf dem Fahrwerk (siehe Foto), in dem Handschuhfach / Werkzeugkasten geprägt / eingeprägt. Sind die Kennzeichnen überall die selben ?
Die Person, die sich um das Fabrikschild gekümmert hat, hätte sich irren können und vielleicht 5 gegen S tauschen können, oder ?
207Driver
Re: Many Questions
I think there is something wrong...
The number of the steel frame and engine is the same, but in the toolbox is an other type and number?!
Re: Many Questions
you'll have to change the manufacturer's data plate !
112442 is not compatible with S57C
207Driver
Re: Many Questions
Have you any idea where i can get a new peugeot manufacturers plate?
Re: Many Questions
hello try to go on " le bon coin" then type on your computer " mors speed" there is a guy rebuilding peugeot manufacturers plate
207Driver
Re: Many Questions
Thank you!
can you tell me if my plate is original? (see picture above)
Re: Many Questions
yes it is, on the new one you'll must write type " s57c" number " 121274", 125 cm3 and it will be ok.
207Driver
Re: Many Questions
I get a new manufacturers plate from www.peugeotscooters.fr
They also have C.O.C. Dokument and certificate of the scooter
